vcBoolProperty
Typed property that holds a value.
Parent: vcProperty
DefaultValueBoolean OR NoneRWGets or sets a default value for this property. Value None means that an explicit default value is not defined.
TypevcPropertyTypeRGets the property type.
ValueBooleanRWGets or sets the property value.
waitForobjectBoolean OR None value,
waitForNotobjectBoolean OR None value,
